what do you think
what do you think
What do you guys think about these heads? Good? or Bad?
Theyre goin on my 347
http://www.latemodelrestoration.com/...0%201&comp=LRS
well i have
eagle 347 stroker
flat top kb piston -6.5cc
f303 cam
stock heads
performer rmp intake bbk 75mm throttle body
24lb injectors
cold air intake
bbk longtubes
off-road h pipe
and im thinking about putting in 410's i wanna be somewhere in the 11's
eagle 347 stroker
f303 cam
stock heads
24lb injectors
cold air intake
bbk longtubes
off-road h pipe
For a budget built weekend warrior it sounds like a descent setup.I would agree you need more cam but what are your goals?Is this a DD a street/track car?
With a few tweaks to the plan the engine sounds like a good low buck motor
well right now its my dd but i dont drive it much im only 17 all i do is drive to school and work. eventually i want to make it a weekend/summer car only, after i get heads and gears. What cam would you guys recommend? im probably going to get afr 185's
