Upper Intake Manifold n00b Questions???
Old 03-26-2009, 04:34 AM
89Mustangn00b
89Mustangn00b's Avatar
Talking Upper Intake Manifold n00b Questions???
Ok this may sound really dumb but I honestly don't know because I havent seen it done and haven't really looked at it. Is it possible to rotate the upper intake manifold 180 degrees so the TB, cold air intake and upper intake manifold are on the right side of the car instead of the left? I have the battery moved to the back and I'd really like to use the space I have on the right for when I put a turbo in, but I'm a n00b like I said and not even sure if it's possible. Lemme know.
89Mustangn00b is offline
Old 03-26-2009, 07:10 AM
Portmaster
Portmaster's Avatar
I've never tried it but I know there are some intake that would work flipped over but most of them no. There are a ton of cars running turbos on both sides so that shouldnt be an issue. If you have to even have to ask this question you may want to rethink the turbo car
Portmaster is offline
Old 03-26-2009, 07:28 AM
86HOGT
86HOGT's Avatar
The Crown Vic and Marquis had them flipped yet they were a different intake I think. I do believe it's possible since I think the bolt pattern is symmetrical but there's no reason to.
86HOGT is offline
Old 03-26-2009, 10:53 AM
87foxgt
87foxgt's Avatar
you should still have enough room to put a turbo in on the right side even if you cant switch it. Or you could just run more tubing to the turbo and stick it where ever you want.
87foxgt is offline
Old 03-26-2009, 11:36 AM
Timspony
SVT Section Moderator
Timspony's Avatar
...sounds like you got your answer!
Timspony is offline
Old 03-26-2009, 12:47 PM
89Mustangn00b
I was just wondering. I didn't want to have to be restricted on the space I had to put a turbo in is why I asked. And I like to be different. Oh well. Guess we'll stick with the norm.
Old 03-26-2009, 03:03 PM
luckythirteen13
luckythirteen13's Avatar
it wouldnt be too hard the only issue would be the throttle cable. with the intake flipped around the cable would have to come from the front to pull the tb open
luckythirteen13 is offline
Old 04-02-2009, 12:07 PM
Slayer420
Slayer420's Avatar
dam thats a crazy *** looking engine bay!!
Slayer420 is offline
Old 04-02-2009, 12:09 PM
Slayer420
Slayer420's Avatar
and yes you can turn it 180
Tivo304
08-28-2023 12:19 PM
Dragonus18
09-09-2015 01:21 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Upper Intake Manifold n00b Questions???
