Steel vs. Aluminum Flywheel
Old 03-27-2009, 02:22 PM
cobrakiller347
cobrakiller347's Avatar
Originally Posted by AdderMk2
you arent listening... you free up lost HP be lightening the parts that spin... the car is still going to accelerate the same.. but in nuetral you would see the engine rev quicker, because there is now less weight to spin
you seem very knowledgeable
cobrakiller347 is offline
Old 03-27-2009, 03:14 PM
AdderMk2
Banned
AdderMk2's Avatar
dont be fooled
and I run aluminum myself
AdderMk2 is offline
Old 03-27-2009, 07:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I also run aluminum in my ride and it is very streetable
mjr46 is offline
Old 03-28-2009, 07:30 PM
15austin
15austin's Avatar
So if I had a car that ran a consistant 13.50s witha steel flywheel, If I put in an aluminum flywheel and nothing else would I get a faster time?
15austin is offline
Old 03-28-2009, 10:59 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
+1 for aluminum.
sn95_331_GT_ yellow is offline
Old 03-29-2009, 07:06 AM
ewgoetz
ewgoetz's Avatar
I was ordering a flywheel form D&D last thursday actualy and hte guy from ther ewas recomending the steel if it was gonna be for street use. If i remember what he said the difference is with the alum it can sputer the engine when first starting off or something like that. I ended up ordering the steel one with my 6 speed.....the end of the week is gonna be like christmas for me.
ewgoetz is offline
Old 03-29-2009, 08:28 AM
Jfsram
Jfsram's Avatar
The difference would be minor but you must understand where the differences come from.
With a launch off idle launch like a typical street tire car would do. Close throttle upshifts. An aluminum will have a slight edge as it has a few less pounds of rotating weight to spin up the drivetrain.
The advantage of a heavy flywheel, especially for a heavy car, small engine. Imagine a high rpm launch, drop the clutch, powershift. This combo would be faster than aluminum.
On the street like driving around a steel flywheel has a slightly smooth idle and taking off from a stop is a tiny bit smoother because as you load the drivetrain the engine will take the load better due a the inertia of a heavy flywheel.
I wish I took a video but I don't have the truck anymore but a 95 Ram 5.2L, 5 speed was the extreme example of heavy flywheels. It's was 40lbs. You could rev the engine, kill the key and release the clutch pedal in first. It would lay rubber with the engine off. Ya a stupid thing to do but to give you an idea, a 7 lbs aluminum flywheel would have just instantly stopped the engine as soon as you introduced any clutch.
Jfsram is offline
Old 03-29-2009, 09:33 AM
Slo5oh
Banned
Slo5oh's Avatar
You also forget the whole purpose of a flywheel. It is to keep up the rotation of the engine via inerta. The less weight, the less inerta. The less inerta, the less mpg while cruising. Granted you could see some improvement while accelerating, you'll make the engine work more to cruise.
Slo5oh is offline
Old 03-29-2009, 01:49 PM
OnyxCobra
OnyxCobra's Avatar
Jeez, i just got my stock one resurfaced. $40 ftw!
OnyxCobra is offline
Old 04-02-2009, 01:05 PM
Slayer420
Slayer420's Avatar
just bought my aluminum i'll let you know how it acts!!!
Slayer420 is offline
baddog671
07-26-2016 01:20 PM
Vrooom
02-21-2016 05:25 PM
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
09-10-2015 08:39 PM
Quick Reply: Steel vs. Aluminum Flywheel
