5 Speed Transmission HELP!
I have a '95 5.0 and my car makes a chirping sound when I don't have pressure on my clutch I know what your going to say "bearing" and it has so slop in the pedal. If I buy on of those firewall adjuster will this fix my problem? Thanks,Brad
the chatter/chirp is your TOB(throw out bearing) means its junk. you'll need to replace it to get rid of the chatter/chirp entirely. the shudder could be your tailshaft bushing. the firewall adjust only adjust the friction point in the pedal.
