need clutch advise!!!!
Old 03-27-2009, 10:46 PM
turbosha
turbosha's Avatar
Default need clutch advise!!!!
so i put a bbk fuel pump,trick flow 75mm tb,steeda egr delete,mallory 6 box,aeromotive f.p reg.set timing ,tps,and idle. runs awsome.so i took my friend for a ride, at the lowest boost setting . (7ish psi).in second gear and punched it.... smoke from tires followed . cool i thought. till i stopped and smelled clutch.bad.now i cant even hot rod around without it slipping.i used to could floor it with 12 psi. and it just take off.more power good.....weak clutch bad... thinking of c4 down the road.this summer will still be 5 speed.
so what is the best holding,,,,fairest priced,,,,replacement clutch out there. i have the "cobra" clutch now.
3.73 gear
275 45 17 bfg drag radials
mostly weekend tooling around .
some track time when clutch goes in.
come on all whats your thoughts. good or bad.
turbosha is offline
Old 03-27-2009, 11:06 PM
lxman1
lxman1's Avatar
I would suggest a center force clutch assembly.
lxman1 is offline
Old 03-27-2009, 11:09 PM
primetime5.0
primetime5.0's Avatar
call up promotion, let them pick a clutch.. mine works perfect from them
primetime5.0 is offline
Old 03-27-2009, 11:28 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
centerforce DF
mjr46 is offline
Old 03-28-2009, 10:48 AM
90lxrider
90lxrider's Avatar
i like the fidanza 6puck (the 4.3 i think) or i also like the SPEC stuff stage 3
90lxrider is offline
Old 03-28-2009, 10:59 AM
cobrakiller347
cobrakiller347's Avatar
i got the centerforce ram stage 2 for like $300 and i really like it i also bought the aluminum quadrant and new cable
cobrakiller347 is offline
Old 03-28-2009, 05:43 PM
minnow81469
minnow81469's Avatar
SPEC all the way awesome clutch kit great prices
minnow81469 is offline
Old 03-28-2009, 05:45 PM
minnow81469
how much hp are you running with that car by the way that will dictate if you need a stage 2 or 3
Old 03-30-2009, 09:28 PM
turbosha
turbosha's Avatar
was at 498 at rear wheels with upgrades should be at 520 ish. so figure 15% drivetrain loss. should equal= 598hp at flywheel.i was looking at ram powergrip hd or dual friction centerforce. i wonder if my factory flywheel resurfaced will be good enough??????
turbosha is offline
mrtrodonet
09-19-2020 03:12 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: need clutch advise!!!!
