h/c/i 302 to a 347?
Old 03-29-2009, 04:58 PM
Epic91GT
Epic91GT's Avatar
Default h/c/i 302 to a 347?
hey guys had a quick question. what would a h/c/i 302 run in the 1/4 with stock suspension. and also would a h/c/i combo bolt right up to a 347 stroker? i know the bore is bigger in the 347 but i didnt know if that effected the heads or cam?
Epic91GT is offline
Old 03-29-2009, 05:03 PM
94ford5liter
94ford5liter's Avatar
Your question is too broad to give a definite answer. There are so many h/c/i setups for a 302, you have to be more specific about what heads, cam, and intake because the power level and quarter mile time can vary greatly.
As far as your other question goes though, the h/c/i to the 347 would be interchangeable.
94ford5liter is offline
Old 03-29-2009, 05:07 PM
Epic91GT
Epic91GT's Avatar
well what is a good streetable car h/c combo im thinkin gt40p intake
i would like to keep the price down
Epic91GT is offline
Old 03-29-2009, 05:16 PM
94ford5liter
If u want a budget build the gt40 stuff would work. If you can find a late 90s explorer you could go with the gt40 heads, and gt40 intake or the gt40p heads and intake. Cam its really about personal choice, stock bottom end can only support up to about 550 lift (or around there can vary from car to car) though before you run into piston to valve clearance problems. However, if you went to a 347 I think most aftermarket stuff usually support up to about 650 lift. Problem with the p heads is you have to run special headers though. Or you could just try to find like some used trick flow heads and use them with the gt40 intake. They would make a lot more power, and I bet you could find some used ones for like 500 bucks.
Old 03-29-2009, 05:17 PM
AdderMk2
Banned
AdderMk2's Avatar
a good quality 302 h/c/i package would choke a 347...
and the bore on a 347 is only .030 larger than a 302 (its the same as a 306)
AdderMk2 is offline
Old 03-29-2009, 05:21 PM
Epic91GT
Epic91GT's Avatar
well what is a good quality h/c/i? and what do they run price wise and in the 1/4
Epic91GT is offline
Old 03-29-2009, 05:26 PM
AdderMk2
Banned
AdderMk2's Avatar
there are too many variables to quote 1/4 mile times based on an H/C/I package... ive seen people drive stock stangs to mid 15 second passes... and i know someone whos stock GT kept up with my cobra, and ran ow 14's
AdderMk2 is offline
Old 03-29-2009, 05:28 PM
Epic91GT
Epic91GT's Avatar
ok well then back to the first part of my question what is considered to be a "good quality" h/c/i combo and what is the approx. cost
Epic91GT is offline
Old 03-29-2009, 05:31 PM
AdderMk2
Banned
AdderMk2's Avatar
a good combo will run you around $2400 if you go with a high end setup...
of you could do a budget swap for up to $1000.. depending on your searching ability
AdderMk2 is offline
Old 03-29-2009, 05:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what's your budget, define that first otherwise it's useless to quote you prices
mjr46 is offline
Quick Reply: h/c/i 302 to a 347?
