Re-use spring dampers?
Old 03-30-2009, 01:30 PM
goathead75
goathead75's Avatar
Default Re-use spring dampers?
I'm installing a set of Eibach Pros and I'm wondering do I need to re-use the spring damper (rubber coil inside the spring) from the stock springs?
goathead75 is offline
Old 03-30-2009, 01:33 PM
grabbem88
grabbem88's Avatar
the pro's were designed as they are it's a specific spring rate...i never reused them, just got new isolators
grabbem88 is offline
Old 03-30-2009, 01:51 PM
goathead75
goathead75's Avatar
The eibach pros are a progressive spring. I did get new poly isolators. Have you had an issues not running the damper?
Old 03-30-2009, 01:54 PM
grabbem88
grabbem88's Avatar
6yrs "knocks on wood" no tire rub or abnormal rebound.
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
mungodrums
09-28-2015 10:54 PM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: Re-use spring dampers?
