Which Balancer
Old 03-31-2009, 05:22 PM
86HOGT
86HOGT's Avatar
Default Which Balancer
When I first built my 347 I needed a 28oz balancer yet one that will work with the pulleys. I ended up going with a CAT brand one (big mistake). I needed to make a 1/2" spacer so the pulleys would align. It started to hammer out the bore and beat on the crank. Only reason I caught it was because they belt flew off two years ago after big burnout hitting 7000 .
I had a balancer that the guy threw in with the stroker kit. It was stock Ford and had a part number starting with E3....1983. It's been on there since. Needed no spacer.
I just tore down the front of the engine to start replacing the timing chain cover gasket and the rubber is starting to peel out the back of it so I figured it would be a good time to replace it. Which one should I use? The engine will be revving 6600 MAX.
86HOGT is offline
Old 03-31-2009, 06:57 PM
AdderMk2
Banned
AdderMk2's Avatar
professional products... I have one and it works great.
although, you will need a spacer, but they sell them per application
AdderMk2 is offline
Old 03-31-2009, 07:20 PM
.boB
.boB's Avatar
Here's a trick I learned the hard way. After you install the balancer, stick your finger in there and feel the crank snout. The lip of the balancer should be past the crank snout by at least 1/8". If it doesn't, your balancer and crank won't last long.
For a low RPM application like that, and quality balancer from Jegs or Summit will work fine. I'v put a lot of miles on a Fluidamper with no issues.
.boB is offline
Old 03-31-2009, 08:50 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
professional products 9006 I believe is the correct balancer and you can get the proper spacer for the 5.0L mustangs, THat's what I did
mjr46 is offline
mjr46
mjr46's Avatar
mjr46 is offline
Old 03-31-2009, 10:22 PM
primetime5.0
primetime5.0's Avatar
ill sell you my sfi PP balancer, im going with a romac
primetime5.0 is offline
Old 04-01-2009, 02:14 AM
86HOGT
86HOGT's Avatar
I think I'm going to get the 80006 http://store.summitracing.com/partde...5&autoview=sku
And which spacer did you guys use? The .950" http://store.summitracing.com/partde...5&autoview=sku
86HOGT is offline
Old 04-01-2009, 02:48 AM
primetime5.0
http://www.latemodelrestoration.com/...0%201&comp=LRS
the only bad thing is that spacer is held on by 2 little screws, and imagine spinning it 6k+... thats why im replacing mine
Old 04-01-2009, 06:17 AM
Portmaster
Portmaster's Avatar
Those little screws just hold it in place, It's held on by the 4 bolts passing through. You are replaceing it for nothing if thats the reason.
Portmaster is offline
Old 04-01-2009, 06:29 AM
Portmaster
Portmaster's Avatar
This is what I'm running on mine. I've been using them since they came on the market for automotive applications. Saw a 15 hp increase in power over a brand new stock balancer without a single change except for the balancer on 461 cubic inch Big Block Chevy. It went from 560 to 575 hp and was able to gain 200 rpm. Ive been using them on all my personal engines ever since. Main bearing wear has become a thing of the past. I did have to buy a 65 dollar March spacer to get the pulley alignment right on my 347
http://store.summitracing.com/partde...26+4294871667+
Quick Reply: Which Balancer
