clutch packs install questions
scroll down the link and you'll see what you need to know
http://www.crownvic.net/ubbthreads/u...3004&site_id=1
http://www.therangerstation.com/tech...actionlock.htm
That was the best directions I found. I just rebuilt mine last week. I used 4 clutches per side and shimmed it all together as tight as I could. I just made sure I used the same amount of shim on both sides, ended up being .010 and i could just barley get the spiders in...it works great!
Oh, and I used royal purple Max gear and that already has the modifier in it.
well i just got them today, they're already prearranged in the sfssfsfshim pattern. looks like i can't even mess it up. however i didn't open the bag, but it looks like it only came with one size shim, a .030. is this going to be all i need?
and its just the clutches i need to soak in fm right? not the steel too.
Daleford
08-10-2015 08:30 PM
