Car dies
Old 04-03-2009, 08:41 PM
89blue5.0
89blue5.0's Avatar
Default Car dies
Just bought an '89 last weekend. Seems to be in good shape. Usual bolt-on goodies. Having one problem. Car is an AOD with Trick Flow intake, BBK cold air kit, E303 cam, SVO under drive pulleys and full exhaust. Have only driven it 4 or 5 times since buying it. One time the CHECK ENGINE light came on. Hasn't happened since, but I still have one problem. Not every time, but every so often when you come to a stop and the car idles the engine RPM's will slightly fluctuate and then the car will die. It always fires right back up. Could this problem along with the ENGINE light coming on have something to do with a faulty emission sensor or something like that? Any help would be greatly appreciated. Thanks.
89blue5.0 is offline
Old 04-03-2009, 09:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
perform a koer test and pull the code, it may have a issue with the IAC motor but first thing to do is pull codes via DIY KOER TEST
mjr46 is offline
Old 04-03-2009, 09:35 PM
89blue5.0
89blue5.0's Avatar
I've read about doing the DIY method in a Haynes Manual and was a little confused. Is it really that difficult to do?
Old 04-03-2009, 09:38 PM
mjr46
mjr46's Avatar
no , one sec and you'll have a link
mjr46 is offline
Old 04-03-2009, 09:39 PM
mjr46
mjr46's Avatar
http://sbftech.com/index.php/topic,2471.0.html
mjr46 is offline
Old 04-03-2009, 09:55 PM
89blue5.0
89blue5.0's Avatar
Now THAT I understand. I will try it out tomorrow and see what I get. Thanks.
Old 04-03-2009, 09:59 PM
mjr46
mjr46's Avatar
Good luck...let us know
mjr46 is offline
Old 04-03-2009, 10:04 PM
89blue5.0
89blue5.0's Avatar
Could you do me a favor? I also just posted another question (I think an easy one) titled Fuel Pressure Question. Could you read that one and respond back. Like I said I'm sure it is a simple one, just thought I would ask. Thanks.
Old 04-03-2009, 10:07 PM
mjr46
mjr46's Avatar
^^already responded
mjr46 is offline
Old 04-03-2009, 10:11 PM
89blue5.0
89blue5.0's Avatar
Saw that, thanks. By the way, good looking '85. Like I said before, I just picked this car up last weekend. Really looking forward to getting back into the Mustang thing again.
Quick Reply: Car dies
