your compression is border line.....bare min needed for combustion is 100 psi, do you notice a loss of coolant,??? I'd monitor coolant level and if you have a pressure tester pump the system up and look for leaks or a drop on the gauge and pull plugs on that side and if pressure on gauge drops and no external leaks are visible see id the cyl's fill with coolant.
