hesitation when giving gas
Ok my brother recently just replaced his upper intake manifold, new valve covers, replaced the seals on his headers, new 70mm tb and new 65 EGR vavle. Put it all together and it ran. Problem is when he jumps on it it'll start to go, then hesitate then go. He said today he unplugged the EGR valve and it's not hesitating anymore??? So what's with his EGR valve?
Ok, I am the brother with the problem. I replaced the EGR valve along with the EGR sensor. If I jump on the gas it will go and then suddenly let up and then go again. Through the gears it is same, shift and jump on it, it almost seems to think about it and then it will go. I am wondering if it could be an ignition problem. It has the original coil, could it be time for a change from the stock coil?
Not necessarily changed, but if it was "bumped" out of whack so-to-speak, by checking the current timing during the problem should give an idea if this is even a possible solution.
Matt's 95 Stang
10-05-2015 07:16 AM
