supercharger??
um i think ur looking at the YSI kit or somethin? Go on www.summitracing.com there are a S*** load of vortech kits for anywere from $1800-$3200, O and you should also look at paxton! (they are owned by vortech also) i have the paxton novi 2000 (car isnt fully running yet) but thing is awsome!!!! and supports up to 900hp
need to try and be a little more resourceful here man, you will probably need to get a 255 pump, 42# injectors, ditch the fmu, wideband would be recomended, do something for a tune (i got a PMS tuner for mine), might want a fuel pressure regulator, colder plugs, possible msd box to help your spark, maff that is calibrated to injectors
well more hp is just a pulley swap away! your starting out at 6psi....... Change the pulley for 12psi and wabam you got over 100hp addition.
But you need all the supporting mods to be able to make all this hp
I know alot of peeps don't like powerdyne but overall the unit isn't bad. If your interested in a set up for a 87 to 93 fox let me know I have a set up I will let go at a good price with a few extra goodies. I bought it but the brackets will not work on mine so I am going a different route.
ya i would personally stay away from them, i have seen/heard some horror stores about those units!
Its not every unit that is bad, there quality standards arnt that great from unit to unit
Most of the stories I always would hear is the customer service issue's and sending there stuff in and taking forever to get it done and back. The one I have is great shape and a BD-11A model I just bought it without knowing about the timing cover being shorter on the 94/95 model and they want too much for brackets to fit mine so I am selling the set up I have and going to put the money in my motor I am working on.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
