smog pump delete
smog pump delete
i'm wanting to remove my smog pump. if its not needed and will free up some space and weight, why not? i'm in FL so no need of emissions issues. i am wanting to keep everything in place for a little just to make sure there arent any problems for a lil, and if there are, i can just put the old belt back on and connect the vacuums.
q. the 2 lines that need to get plugged coming from the back of the heads, can they be plugged at the line that comes out to where the hoses connected, instead of at the back of the heads? bolts are tight, hard to get to, and wanting to keep it for a lil so if it needs to get hooked back up it wont take long.
i'm only concerned about keeping it to where it can be hooked back up quickly only cuz i heard of issues with waterpumps from using a shorter belt. UP's except alt, had to use a 75.5" belt. 76" rubbed and anything shorter really didnt want to go on. hearing a lil noise from the AC that i didnt notice before. i want to plug it properly but dont want to have to hook it all back up if other things just go south with it off. kinda in a testing phaze i guess.
that was my idea on keeping those until there i had to go in further and had some more room.
the sensor type plugs that go to the vacuum lines, can those be completely removed or do they have to be plugged to something?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
