car jerks/bucks when let off the gas
for the most part, when i'm just cruising, if i let all the way off the gas, my car will kinda jerk or buck whatever you wanna call it. it does this a couple times, then stops. and it only happens sometimes. sometimes its worse then others. it seems like its coming from either the trans or rear end. i know my trans is already on its way out? could this be it? also, i've got some elcheapo lmr control arms on the back, think they're just crap? i got them for free so i can't really get pissed if thats the problem.
and it did this before and after i redid my rear end. i'm just now getting fed up with it, lol.
The cheaper control arms can cause a binding similar to what you are describing. The more expensive ones are non-binding. In my old car I had a binding similar to that with my bbk control arms. Could also be your rear end locking up, but if it is new I doubt that.
pinion play? like the rear pinion? i couldn't see that. this happened both before and after i went thru the rear end. its happened since i've replaced the c/a's, but that was also when i put my motor in so i wasn't sure if it was the trans going. would it be the uppers causing this? they looked pretty weak, i was almost afraid of putting them on.
