Can't find the miss
there is a ground wire running from the bat. to the timing cover and check to make sure none of the ceramic is cracked on the spark plugs and also make sure that the injector wires are pushed in all of the way
engine ground from timing cover to chassy, cylinder head to firewall. replace them both with larger, finer stranded wire. i would also ground your alternator too.
i upgraded the following, pretty much a "bulletproof" grounding system. my charging system has been flawless ever since these upgrades and i highly suggest them.
4awg: computer to chassy, alt to chassy, cylinder head to firewall.
0/1awg: engine to chassy, batter to ground.
Alright here are the codes:
KOEO
67:Park Neutral Position Switch Circuit Open; A/C On -Manual (O), Manual Lever Position Sensor Out Of Range/A/C On (M,O), Clutch Switch Circuit Failure (M)
82:Secondary Air Bypass Circuit Failure
KOER
42: System Indicates Rich -passenger side(R), No o2 Sensor Switching Detected. always rich -passenger side
33: EGR Valve Opening Not Detected
Cylinder Balance Test
1st: 2
2nd: 8
3rd: 9
KOEO
KOER
1st: 2
2nd: 8
3rd: 9
jaiidutch
09-14-2015 10:29 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
