Replacing Manifold gaskets
The last 2 bolts on the each side of the engine backed off on me and I tightened them up and i still get a ticking under load. Once the bolts back off do the gaskets blowout? Does anyone have any tips for replacing the gaskets or is it pretty simple?
I have never used Loctite on them and I'm not so sure it would hold up to the heat. You could try it, but use a medium strength. Torque spec’s if you look on-line you should be able to find it, I like most don't use a torque spec for exhaust manifold bolts. I just make sure they are tight. Also, many don't know this but you can use a good high heat RTV in place of gaskets with zero issues. In some cases it's preferred, but you need allot of room between the header flange and the head to properly apply the RTV.
I looked into the stage 8 fasteners and they are a little over the top for my car by the time I pay to get them to Canada. I'm assuming mine are blown out for sure then because the back 2 bolts were able to come out with my fingers haha. I guess I will have to make sure they keep torqued.
remove all the center bolts and loosen the last two up a good amount. you should be able to pop the gasket out with a screw driver.
the new one just drops in place..
and I recommend these!
http://cgi.ebay.com/ebaymotors/LOCKI...ayphotohosting
