on my 6th clutch cable in a week.
Old 04-07-2009, 06:48 PM
84conversion50
84conversion50's Avatar
Default on my 6th clutch cable in a week.
ok so i changed my first cable out with one from carquest because it was stretched out and you had to have it to the floor to disengage the clutch. that one worked for a day and broke the crimp to the housing at the firewall. so i exchanged it for a new one that they said was revised and it broke the crimp down at the bracket where it holds it just before the clutch fork. after dealing with a few of these i switched back to the original stretched cable that was definitely worn out and shimmed it away from the firewall so it would work for a few days until i got the steeda cable i ordered. on the way home today it broke the cable at the clutch fork.
i ordered a new steeda adjustable cable and aluminum quadrant but i dont want to be wasting money having this one break again. The clutch doesnt seem to bind and the cables dont either.
84conversion50 is offline
Old 04-07-2009, 07:11 PM
PJC Racing
PJC Racing's Avatar
Get an original Ford cable.
PJC Racing is offline
Old 04-07-2009, 07:12 PM
84conversion50
will it break?
Old 04-07-2009, 07:45 PM
ctgreddy
ctgreddy's Avatar
i've been doing research on my 5sp swap and everyone says to use ONLY oem ford cables. the adjustable ones and all aftermarket ones are lesser quality. they also stretch very easily. so get the oem, if it breaks, you've got another problem.
ctgreddy is offline
Old 04-07-2009, 08:05 PM
84conversion50
to bad i already ordered the steeda.
Old 04-07-2009, 08:10 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
AFTER THE INSTALL OF the cable, how is pedal effort???? excessive at all??? if not try the ford racing cable, mine has been going strong for 8 years now
mjr46 is offline
Old 04-07-2009, 08:19 PM
84conversion50
was waiting for your post mjr. steeda claims that there cable is the same as the ford racing cable. the pedal effort is no harder than the original cable that was just worn out was. my dad says its a little hard but not excessive.
Old 04-07-2009, 08:54 PM
Jon82387
Jon82387's Avatar
wow 6 cables? you either have really bad luck or theres something more then just a cable wrong. I swapped my original for a JEGS version that has the adjuster on the bellhousing and i also have a new quadrant/firewall adjuster and i can dial my clutch to engage way up top or down low on the pedal.
Kinda sounds like you have somethin else wrong other then the cable?
Jon82387 is offline
Old 04-07-2009, 10:05 PM
84conversion50
my positive way of looking at it is the carquest ones were pure junk and teh original i tried to make work again was frayed to begin with and when i shimmed it at the firewall it put more stress and broke the already breaking cable. Steeda FTW?
Old 04-07-2009, 10:09 PM
primetime5.0
primetime5.0's Avatar
lol my buddy just broke a steeda one after a few days.. get the MM ford cable
primetime5.0 is offline
Quick Reply: on my 6th clutch cable in a week.
