will a 93 cobra tps work on a '88?
Old 04-08-2009, 02:30 PM
camaroeater
camaroeater's Avatar
Default will a 93 cobra tps work on a '88?
i think my stock tps is gone, so i want to put the cobra one on.
camaroeater is offline
Old 04-08-2009, 02:34 PM
mustangmike33
mustangmike33's Avatar
i assume it will work, but not sure. if you do put it on, make sure you set it to the right specs. i think the specs for your car are 0.9-0.95. something like that.
mustangmike33 is offline
Old 04-08-2009, 02:54 PM
Joel5.0
Joel5.0's Avatar
Does the EEC show a TPS failure code?......
Joel5.0 is offline
Old 04-08-2009, 03:09 PM
grabbem88
grabbem88's Avatar
they are different,and i'm totally sure why,but i'd be checking if you had a tps failure code first<like joel offered>
part number's are different,but they look similiar
grabbem88 is offline
Old 04-08-2009, 03:34 PM
camaroeater
im getting code 63, tps signal too low. I have set the tps to .098 twice, then when i run codes its back.
Old 04-08-2009, 03:36 PM
mustangmike33
switch it. you should be ok as long as you set it to the right specs
Diode Dynamics
28
05-26-2022 12:02 PM
raleigh05GTO
09-04-2015 07:09 AM
amandahchase
09-03-2015 10:09 AM
rocket22
08-28-2015 07:08 PM
svtrosey
SVT Forums
08-15-2015 09:09 PM
Quick Reply: will a 93 cobra tps work on a '88?
