electric fan???
Old 04-08-2009, 02:41 PM
81ponycar
81ponycar's Avatar
Default electric fan???
My 94 gt runs at 210 degrees and doesnt move. Is that where they should be running at because i put a 160 thermostate in it and it still runs at 210 degrees. And my electric fan wont turn on and i jumped it to see if it worked and it ran fine and with no sqeaks... Does anyone know what sensor turns the electric fan on and does your guys's 94 gts run at 210?? Thanks for your help.
81ponycar is offline
Old 04-08-2009, 02:51 PM
mustangmike33
mustangmike33's Avatar
im not a sn-95 guy, but to help with your fan problem, id cut the wires and run them to a toggle switch. that way once you start your car, flip the switch and the fans will be running non stop. it shouldnt drag your charge level down, and itll run alot cooler. as far as the actual temperature of 210, couldnt tell you. it may be a bad thermostat, or someone gave you a 210 thinking it was a 160, has happened to me before. buy a 160 and they give you a 210. so double check that and re-wire your fans.
mustangmike33 is offline
Old 04-08-2009, 02:58 PM
81ponycar
81ponycar's Avatar
The thermostate is my fourth one i tried lol. I would do that to the fan but im trying to make this car like its bone stock even tho its far from it Thanks for your advice
Old 04-08-2009, 03:04 PM
Joel5.0
Joel5.0's Avatar
SN95 EEC turns the fan using the input from the coolant temp sensor (ECT) in low speed @208°F and off @204°F. IOW.... 210°F is normal op temp.
Joel5.0 is offline
Old 04-08-2009, 03:17 PM
81ponycar
81ponycar's Avatar
so if its runnin close to 210 the fan shouldnt be on? so im not having problems? thanks very much
Old 04-08-2009, 06:23 PM
Tony71502
Tony71502's Avatar
Hmm, could your rad be bad? Im running the stock t-stat w/ a somewhat new rad and flex a lite fan(yeah its going to be replaced with efan soon cuz they explode). IDK if my stat was replaced by the previous owner or not... but I run a constant 180.
Tony71502 is offline
Old 04-08-2009, 10:24 PM
Jfsram
Jfsram's Avatar
When you jump the fan, does it pull the temperature down?
Rewiring the fan to come on with the key is bad advice. You are eliminating all the advantages of having an electric fan.
If the radiator was bad, the fans would be on trying to cool it down.
Forcing the fan on only tells you the fans work. Something needs to tell the computer to turn the fans on. That's the temperature sensor. When the computer sees the numbers that Joel posted, it supposed to energize the fan relay.
Jfsram is offline
Old 04-09-2009, 01:19 AM
FordMustangXBA
FordMustangXBA's Avatar
Why the 160 t-stat? I was under the impression that the 180 is perfectly fine.
FordMustangXBA is offline
Old 04-11-2009, 01:21 AM
Foxbody87
Foxbody87's Avatar
I just got finished installing a new rad. and twin electric fans, and the relay/control that came with my fans had a 3/4" npt sensor that screwed into the therm. housing, or in some cases the radiator, and it was adjustable to come on when you wanted it to. also was able to either run it to a toggle switch (which i did) or into the ac clutch so when the ac was on the fans would, which that would help you keep a stock look with no switches inside
Foxbody87 is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
Quick Reply: electric fan???
