new tps, same problem
Old 04-08-2009, 08:33 PM
camaroeater
camaroeater's Avatar
Default new tps, same problem
only in first gear its as if someone is turning fuel on and off. I put on a 93 cobra tps and the problem is worse. Ive about had it with this piece of ****! Besides this problem car runs PERFECT idles perfect at 750 always. I know its gonna be a guessing game on what to replace first, so Im open to ideas. thanx
camaroeater is offline
Old 04-08-2009, 08:45 PM
84conversion50
84conversion50's Avatar
ignition control module?
84conversion50 is offline
Old 04-09-2009, 08:12 AM
kilby94
kilby94's Avatar
Have you pulled codes? If so, what are they?
Have you cleaned IAC, MAF, 10-pin connectors?
Checked vacuum?
I would just go through it and check everything you can, and give everything a thorough cleaning..
kilby94 is offline
Seanam
10-04-2015 10:15 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
mdj89
09-23-2015 08:49 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: new tps, same problem
