Broken Bolt, Help, Please!!!
I was doing a simple timing cover gasket change on my 94 5.0 I broke the top right timing cover bolt. So a simple job turned into this..... I need all ideas.
Thank you in advance
ya if you have a torch do that and grab it right away dont let it cool.
2. drill pilot hole and use an extractor. and ya the center punch is so that the bit dont wander all over
either way use lots of lube
before you go screwing up what you have sticking out of the block see if you can try these things. If you have access to a welder weld a nut to the end of it and run it out. the block being cast cannot be welded to and it will only stick to the bolt. or you can jbweld a nut to it and let it set up over night and run it out.
