Hear the ping?!?!? What is it!?! HELP?!
grab a cheap mechanics stethoscope, you should be able to figure out if its a exhaust leak. it sounds like just a leak. it could be a lifter failing, some freeplay in the vlavetrain. check and see if it's a leak first then pull the valve cover and start checkin it out
I would like to know what that sound is too.My 94 gt makes the same sound at idle, sounds like it is coming from the driver side around the back of the motor, If you find out what it is tell me so I can fix mine.
sounds like a loose rocker you don't need a feeler gauge or anything just pull the valve cover off and make sure all your rockers are tight but if you want to know the real way..
stock rockers are not adjustable its just a bolt you would have to depress the lifter and check the clearance with a feeler gauge if thats not in tolerance you have to get all new pushrods! desired .123-.146" allowable .098-.198
Good Luck
Good Luck
hey thanks alot guys...is it hard to take the valve cover off? do i need to take intake off??? or is it just a couple bolts then its out? All new pushrods omg what a b*tch i have no clue what i am doing is it a hard project???
umm instead of going with pulling the valve cover... just replace your exhaust gasket. you may have even lost a couple bolts. thats not a ping, it's a tick which sounds MUCH more like a exhaust gasket leaking than it does anything else
this is good to hear. i have same type of noise from around the #4. gt40p's going in soon. which will have new rockers, springs, valves, headers, gaskets.
should/can the pushrods be replaced then?
can the vallve covers be removed without anything else disconnected? if so can the engine run with them off? <<<maybe stupid question just wondering on how to check if the rockers are hitting.
