Help......
Help......
Been Having problems with car wanting to idle at 1000-1200 RPM's, then when driving the car and shifting into another gear RPM's hang. Checked the timing 3-4 times and it is where it should be (12* BTDC).Checked the TPS .98 Volts,Reset Base Idle,Cleaned the MAF. CAr also runs really lean at idle.
Ran a KOEO/KOER test today on my 94 GT...
KOEO
code
564-Drive fan (EDF)-circuit failure???
332-Insufficient EGR flow detected? (I took ALL the EGR stuff off...)
KOER
Code
314- Thermactor Air System inoperative during engine run self-test (Bank #2 with dual oxygen sensors)???
311- Thermactor Air System problem-no operation during Engine Run Self-Test (Bank #1)???
Cylinder Balance Test
Code-9 (System Pass)
KOEO
code
KOER
Code
ON THE 94 idle hang between shifts is normal, you will not be able to remove it, it is what is know as the idle dashpot function, I believe ford did that to lessen the harshness between shifts so as to reduce the number of t-5 warranty claims.
