problem worse, can't drive now....help!
#31
just replaced the module with a Napa one and the problem is NOT gone. If anything its worse. I cleaned the module mating surface real good, applied a 1/32 coat of dielectric grease. I even performed a base idle reset since battery was disconnected and then set timing to 14* how it was before. What else could it be?
#32
have you pulled codes? ICM's only run like 25 bucks.
have you even test the PIP/hall sensor? you could save yourself time and money testing your equipment vs buying things.
#36
i set timing to 26* with spout out and left it off. I test drove it and the problem is worse w/o spout it even made a noise that sounded like the flywheel grinding. Also, when i first fired it up after fixing it, i could hear a noise from where the tranny was, it sounded like the h pipe vibrating against something Then after a minute or so it went away.
#37
#38
joel had him lock the timing out..which took the ecu out of the equation.
so what does this leave to check?
#39
Joel, i reved the engine over 4K and the needle is steady, doesn't flucuate or anything. I did hear that vibrating noise near midpipe once the needle is over 2500rpms. I adjusted my midpipe not too long ago, so im sure its not loose. What could that noise be? It sounds like the midpipe is against the frame vibrating.
#40
Problem is Solved!!!
so last night im looking at parts on the web and I end up looking at a close up photo of my
Accel rotor. I look at it and realize that the metal tab on the rotor is bent upwards further than mine and remember that my was bent downward more. So i bent the metal tab up on my rotor and took it for a ride. I drove almost perfect, cut out just a couple times, where before i could only drive 20ft. Also, i noticed that the metal ring that goes around dizzy cap button was worn down on one side. I just installed a new MSD cap and rotor and im 100% now, it drives perfect.
I've replaced the coil, wires, and ignition module with no luck and get this, just yesterday i ordered a stock dizzy for $250... when it was a $5 dollar part i needed. I want to thank everyone for input on this problem.
ShaneB26154
35
03-04-2021 04:05 AM
