Question about stainless steel brake lines
I installed a set of front SS hoses on my car last season, and ever since I have gotten a lot of chatter from the calipers. The sliders are tight, new pads, etc.. Any suggestions on what to do to cure this annoying noise? Thanks
I cant figure it out. All the parts were new when installed. New calipers, pads, sliders, rotors and braided lines.
Every time i hit a bump i get chatter from the brakes. Have checked everything else in the front end and everything is either tight or new.
Ya.. There is nothing else it could be. It started right after I installed new parts as described above. Removed both tires and inspected everything again, and nothing is loose except the new calipers have a little bit of play on the sliders. I had a friend mention that it could be since the SS lines don't have the bend that the factory bend have. The factory has a steel tub along with the hose, where the SS is just the hose.
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
