heads
04-11-2009, 08:43 PM
heads
i have some old 351 heads, 79 i believe? they dont have any casting numbers other than 351 and one has 11 and one has 13 stamped on it. there also reversable. worth anything to use them? they have a full set of crane rr 1.6's
04-11-2009, 09:23 PM
D.R. THE PATHETIC DORK
they are nothing special, no different than an e7 head and in fact thay are worse as the cumbustion chambers are slightly larger I believe = lower compression
04-11-2009, 10:03 PM
so keep the rockers dump the heads?
04-11-2009, 10:10 PM
are they pedastal mount roller rockers??...also any pics of the heads??
04-11-2009, 10:14 PM
they have there own studs to make them adjustable
04-11-2009, 10:44 PM
you mean the rockers have a bolt that bolts onto the head?? or do the heads have studs that are screwed into them or pressed in??
04-11-2009, 10:45 PM
04-11-2009, 10:48 PM
hmmmm, any pics of the heads and cumbustion chambers???
04-11-2009, 10:56 PM
will take pics of all angles monday, there at my shop.
04-12-2009, 12:57 PM
look on the underside of the intake runners for a casting number
