worth changin rotors?
ELEKTRO-FIDE Moderator
Location: In Geo-synchronous orbit over redass' bathroom,
look what i quoted you on then what you just said...you can't compare what you said as a reference to an example,because it's a fact that if you had stock brakes you would be butt puckering after the traps...
a 4 lug lincoln rotor would be better than the paper plates found on an old fox..
what's the price you can afford simpsonfan13? $500...would get you alot of hindsight
brake lines...#wil-220-6471 $69.95
rotors/pads..#sum kar8126ps $143.95 for the set
$213.80 will save your butt and will help the car too
I had an issue with my brakes locking up but thats because the shoes were worn down to the metal, the calipers stuck, and the wheel cylinders leaked but thats because they are probably the factory stuff from 25+years ago. After replacing and adjusting they were awesome. All it takes is someone who knows what they are doing and the proper adjustments and stock brakes will work just fine. Yes they can be a hell of alot better but just like anything else if they are properly taken care of they will not let you down.
the question was "is it worth changing rotors"?....And your question to me was "WHY NOT"??? everything I replied to was on topic and in refrence to the worth, for the intended use a decent set of pads will suffice, just because you haven't tried it an had sucess doesn't mean others haven't suceeded where you failed......you aren't the first to dispute this point with me and you won't be the last naysayer I prove wrong in ref to my achievements.....thread done.
so back to topic...yes it is!..IN YOUR OPINION
you can read all the consumer reports,and how they rate/grade the brakes all we want.
it's how "you" feel how safe or not safe they are...compared to today's technology and standards to what was 25 yrs ago there is alway's room for improvement
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
09-16-2015 07:53 PM
