Engine building 101...project semi-n00b
depends on what level of hp you want to achieve, that block will support a little more than a roller block but if your whole goal lets say is only 300 hp then for the cost it would take to convert that block you could of just picked up a roller block on the cheap, I pick them up for often less than 150.00
How much power would the engine be able to handle with those forged pistons in the kit I linked a few posts back? I'd like somewhere around 350-400rwhp, either with a custom Eaton m112 set up or a turbo system. I want something with a good amount of power, but I also dont want it to be so crazy that its unreliable and or breaking things.
Is this all I'd need to use a roller cam on my current engine?
http://store.summitracing.com/partde...0&autoview=sku
