Need injector and MAF/TB sizing suggestion for 393 stroker
Granted this is going in an old bronco, but it runs mustang electronics.
It is a mild cam naturally aspirated 393 stroker (approx 9.7:1 compression).. RPM heads P&P, Lightning lower, Explorer upper.. doesnt see RPMs much past 5500 .. 90% of the time under 4k.
I need some suggestions on the MAF/TB sizes as well as injectors.
I dont understand why you would have a MAF substantially bigger than your TB.. so unless you guys convince me otherwise, I would like to keep them fairly matched..
I had been thinking about 30#s w/75mm ... but some reading on various forums has me thinking 42#s w/90mm... I will be porting the upper, but opening it to 90mm seems like I am asking a lot of the stock casting.
Ok.. so lets hear your thoughts!
Thanks in advance.
Thanks in advance.
09-10-2015 11:46 AM
Other Professional Racing
09-10-2015 11:41 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
