lil help choosing an intake?
i am ready to buy an intake for my car, and i could use a lil help i was looking at the edelbrock performer rpm air gap but donno if theres a better one for my set up. i have a 347, with canfeild 195 heads with competition bowl blend, i plan on running a holley street avenger 670 carb and below are my cam specs. thanks for any help
intake:
AT .006: 276.01
AT .020: 252.34
At .050: 224.32
LOBE AREA AT .050: 28.15 In*Deg
AT .200: 148.98
LOBE LIFT: .37749"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .604"
LOBE CENTERLINE: 110.33ATDC
OPEN AT .050: 1.83 BTDC
CLOSE AT .50: 42.49 ABDC
LIFT AT TDC: .0499" @ 110.33 ATDC Intake Center
Exhaust:
AT .006: 307.22
AT .020: 272.58
At .050: 240.69
LOBE AREA AT .050: 28.76 In*Deg
AT .200: 154.41
LOBE LIFT: .35999"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .576"
LOBE CENTERLINE: 115.35BTDC
OPEN AT .050: 55.69 BBDC
CLOSE AT .50: 5.00 ABDC
LIFT AT TDC: .0682" @ 115.35 BTDC Entake Center
Notes
Cranking Compression 185 PSI
Idle Vacuum 13.5"
Idle RPM 800 RPM to 900 RPM
Peak Torque 4600 RPM
Peak Horsepower 6100 RPM
Torque Converter Stick Shift
Sharting Shift Point 6800 RPM
Starting Cross RPM 7000 RPM to 7200 RPM
REDLINE 7400 RPM
intake:
AT .006: 276.01
AT .020: 252.34
At .050: 224.32
AT .200: 148.98
LOBE LIFT: .37749"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .604"
Exhaust:
AT .006: 307.22
AT .020: 272.58
At .050: 240.69
AT .200: 154.41
LOBE LIFT: .35999"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .576"
Notes
Idle Vacuum 13.5"
REDLINE 7400 RPM
If it's a street setup, RPM Air Gap. It might make a bit more peak hp with something like a Vic Jr, and still run well on the street, but a single plane might not make any more average top end power if you're shifting it in the 6's than the Air Gap.
The Street Avengers are decent carbs, I had one, but for a performance setup spend the money on a good carb. I'm running a Quickfuel right now, badass carb. EVERYTHING is adjustable, even on their street carbs, jets, air bleeds, idle feed restriction, power valve channel restriction, even the metering blocks can have restrictors placed in the emulsion circuits, or you can upgrade to a fully adjustable 4 or 5 circuit emulsion metering block. Basically you can tune it as accurately as an EFI setup, and their customer service is excellent.
YOUR COMBO APPEARS TO HAVE BEEN designed by CI and most likely the standard there is a victor jr.......so go with that as others have stated, I had a race prepped 750 designed for my combo by one of the above carb places I mentioned.
