still hesitating!!
still hesitating!!
ok so now i've changed the cap, rotor, spark plugs, cleaned the air filter, and checked the wires and no change at all. its hesitating really bad now to where it feels like its bouncing and its only getting worse. what else can i check? thanks
does it do it at crusing speeds or at wot cause before i had a problem like that but in cruising speeds it would hesitate real bad like if my car was bouncing back and forth and ever since i replace my maf that hesitation went away
you should take out that maf and try and clean it with some maf cleaner even though it looks clean wipe the little resistors with a Q tip and heres info on how to check tps
if that doesnt work pull codes using a paper clip and reading how many times it flashes
http://www.muscularmustangs.com/tps.php
Ok so I got a mechanic to check it and he pulled the codes and th only one that came up was for the fan control. He cleaned the maf with brake cleaner and now accelerates like before but it still hesitates. He said it was because of the egr valve and that I need a new one. Oh and he also said that it was running rich.
