Double checkin' on smog delete...
So I unplug and cap off the vacuum lines on these 3 parts? I then can remove them right?
(I un-bolted the top part so yall can see all 3!)
What is this: Its at the bottom of my firewall on the passenger side..
Also, Is this relay stock? And is it supposed to be hooked up? It doesnt look like its been hooked up for a long time...
Thanx
Thanx
you can remove those solenoids and toss them and zip tie wires or hide them and plug the egr as for the relay i have two there one of them is for the fuel pump and the other is for the wot ac cut off switch i have the same hole in firewall with nothing
I bought an EGR block-off plate off of ebay. And when I took my EGR off my lower bolt is bigger then the 2 bolts that came with the plate. So I bought a bolt and washer from the hardware store.
The bolt doesnt sit in the "groove/hole" of the plate.. I'm just wondering if that will be ok for sealing it off!?! Should I RTV it?
Thanx
Thanx
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
