Mass Air Meter and ERG Plate
Old 04-16-2009, 05:46 PM
89Mustangn00b
89Mustangn00b's Avatar
Default Mass Air Meter and ERG Plate
ok first question. Why do I need an EGR plate? First of all what is it? Why cant I put an EGR spacer in the spot instead of the plate? Next I'm going to be going with 24lb fuel injectors and wanna put either a 73mm Mass Air Meter or a 76mm Mass Air Meter in... Not sure which one so gimme some advice.
89Mustangn00b is offline
Old 04-16-2009, 06:16 PM
AdderMk2
Banned
AdderMk2's Avatar
list your mods and ill tell you if you should even waste the time and money putting 24# injectors in
AdderMk2 is offline
Old 04-16-2009, 07:40 PM
89Mustangn00b
.512/.512 cam, adjustable rocker arms, cold air intake, Edelbrock upper intake manifold, gt40 heads, stiffer suspension added b4 i got it so not sure what it is.
What I wanna/thinking bout getting is...
1. either 30 or 42lb injectors
2. 73mm or 76mm mass air meter
3. fuel pressure regulator
4. 70mm or 75mm BBK TB and ERG plate
5. Either a NOVI 2000 or 1000
Old 04-16-2009, 08:04 PM
AdderMk2
Banned
AdderMk2's Avatar
you should hold off on doing anything else until you decide if you are going to S/c or not.
since everything you have listed there all is sorta dependant on that fact
AdderMk2 is offline
Dathan
10-05-2015 05:52 AM
Explosive
10-02-2015 07:45 AM
fastbackford351
10-01-2015 12:24 PM
winner99
09-30-2015 07:04 PM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: Mass Air Meter and ERG Plate
