who makes 3.5" or longer wheel studs
Im trying to find a comapny that makes a 3.5" or longer wheel studs with a .618 knurl so that the studs will come through the lugnuts to meet nhra rules, problem is i can't find anyone that makes them longer then 3" in a .618 knurl
I have to use a spacer so that my prostars will fit and clear my wilwood brakes in back, and with the 3" the studs dont come through the open lugnuts and I was told they have to to be NHRA legal. Im about a half inch from them sticking out so if I could find 3.5's that would be perfect
et streets non radial right now and a pair of slicks eventually. The spacer is only 1/4" and its painted black to match the hub. unless i took the wheel off you can't see that its there. Im hoping to run a 10.9x with spray but im in the low low 11's depending on the track prep right now
