HELP I JUST INSTALLED CAMSHAFT
Old 04-19-2009, 12:37 PM
AntiRiceRacing
AntiRiceRacing's Avatar
I hope you broke in the cam correctly...
AntiRiceRacing is offline
Old 04-19-2009, 01:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
cam swap = spring swap
mjr46 is offline
Old 04-19-2009, 01:48 PM
Portmaster
Portmaster's Avatar
If you didn't break the cam in you may be starting to wipe the lobes off the cam.
Portmaster is offline
Old 04-19-2009, 02:09 PM
jthorn9
The Godfather
jthorn9's Avatar
Several problems here as stated:
Stock heads
Didn't change the springs
Willing to bet you didn't change the push rods or rollers
Didn't get it tuned (although not mandatory)
Wrong cam for the car
jthorn9 is offline
Old 04-20-2009, 02:44 AM
xx95gt302xx
xx95gt302xx's Avatar
thank you for all your comments , yes my timing was off a tooth and i didnt know mustang had a "Pill" wich u gotta remove to time them and also seems like my mass airflow sensor got messed up on the prosses . but why is the cam wrong for the car . it said it was for 5.0 or 302?? i didnt install the lifters that come with that kit , i used new roller lifters....
xx95gt302xx is offline
Old 04-20-2009, 04:02 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Well at least you got it straightened out.
projectresto83 is offline
Old 04-20-2009, 08:06 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
IMO it is the wrong cam based on the rest of your mods (or lack of). What I would do personally is to put the stocker back in and run a set of Crane valve springs. This will allow you to rev the engine higher and let it pull all the way to 6000 rpm. With the stock cam and springs you hit valve float right around 5000 rpm and make less power. The stock valve springs are junk on these engines, they really are not even enough for the stock cam. FWIW I have put combos together that have run in the 12's on a stock cam with GT40 heads and intake.
JD1969 is offline
Old 04-20-2009, 08:10 AM
AdderMk2
Banned
AdderMk2's Avatar
is this the cam kit you bought
http://performanceparts.com/part.php?partID=2096
AdderMk2 is offline
Old 04-20-2009, 08:20 AM
AntiRiceRacing
Fits 1962-1987, Small block Ford V8 (except '82-'95 302/5.0L)
Old 04-20-2009, 08:27 AM
Joel5.0
Joel5.0's Avatar
That camshaft (if it's a Hydraulic Flat tappet) is getting wiped........ and the sedimentation coming out of it will eventually cause the oil pump to seize, if you're lucky enough not that have it cause more damage to the engine...... ask me how I know.
Joel5.0 is offline
Quick Reply: HELP I JUST INSTALLED CAMSHAFT
