Crane cams fireball HI-6 any good?
Old 04-19-2009, 02:17 PM
86GT 93LX
86GT 93LX's Avatar
Default Crane cams fireball HI-6 any good?
i got a Crane cams Fireball HI-6 ignitition part number 6000-6420 and a crane cams fireball ps91 performance coil part number 730-0091.
anyone running this on their stang?should i just sell it or is it worth using it? the coil and module can be run seperate or together
86GT 93LX is offline
Old 04-19-2009, 02:23 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Its a great box and coil. When I go to EFI I am getting that setup. The thing I like about it most over MSD is that the rev limiter is on the box already and you don't have to buy different pills to change it.
projectresto83 is offline
Old 04-19-2009, 04:01 PM
86GT 93LX
86GT 93LX's Avatar
so how much is it actually worth?
and what kinda benefit will it give me over stock? it came off a friends xj jeep 4.0 i got for helping him with fixing stuff. i found some pdf stuff on how to wire it, it just shows it hooking up inbetween the coil wires
Old 04-20-2009, 02:18 AM
86GT 93LX
86GT 93LX's Avatar
oh just so you know the hi-6 can be used with even points ignition. it even works with hondas with internal coil distributors. so you dont have to wait till you go efi.
i installed it today with the coil as well had to get a lil creative to make it all fit nicely. the motor runs smoother but i dont notice anything really.and i hooked it up according to this pdf and no tach.and it says normally it works fine on tfi fordsbut not on this one. theres a tach signal wire which i geuss i can hook up to which ever of the 2 green and yellow wires that run to the tach off the coil plug. but with the hi-6 it piggybacks into the the coil plug so the tach doesnt work
heres the pdf link if youre interested in running it non efi
http://cranecams.com/pdf/90006000a.pdf
Old 04-20-2009, 08:10 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Its not going to give you much if any power (unless your current ignition is in really bad shape). What it will do is give you a stronger , more even spark, down the road if you add a power adder it will be very important. Also the way the rev limiter works is better than how the stocker works.
JD1969 is offline
Old 04-20-2009, 08:53 AM
Portmaster
Portmaster's Avatar
It's a good unit. Very durable.
Portmaster is offline
Old 04-20-2009, 10:39 AM
86GT 93LX
86GT 93LX's Avatar
any idea how to make my stock tach work? i dont like the location i have mounted either ill post a pic later.
so how does the stock rev limiter work that this is able to bypass it?
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
vintageaion
09-08-2015 10:45 AM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Crane cams fireball HI-6 any good?
