Driveshaft vibration after clutch swap
Old 04-21-2009, 10:12 AM
mattkoly
mattkoly's Avatar
Default Driveshaft vibration after clutch swap
I recently did a clutch swap on my 94 cobra, everything is smooth up to 80 then it’s like earthquake city and I can feel it in the rear for sure. my thoughts are it’s got to be from tranny back because it doesn’t change with motor RPM just speed (driveshaft RPM).
So I understand that I could have installed my driveshaft out of phase 180 degrees, what I don’t understand is why it works that way. I have found a couple of posts here and else where that ask the same question but no real answer as to what the balance weights on the driveshaft "balance out" up or down stream.
Does anybody know what is balanced out by driveshaft that would cause vibration if put in incorrectly phased?
mattkoly is offline
Old 04-21-2009, 10:33 AM
67mustang302
67mustang302's Avatar
Are you sure you didn't somehow knock a weight off while it was out, or forget to tighten the trans mount, and have you checked the u joints?
67mustang302 is offline
Old 04-21-2009, 10:48 AM
mattkoly
mattkoly's Avatar
U joints are new, yes i could have forgotten to tighten a trans mount, that was something I was planning to check but it's not really likely and i will double check the weights but I remember checking to see if they were fastened well before I put it back in.
mattkoly is offline
Old 04-21-2009, 04:10 PM
Tony71502
Tony71502's Avatar
Well, there are 4 diff positions you could have installed the driveshaft, GM's have two. But regardless, that wouldn't make a difference.
Tony71502 is offline
Old 04-21-2009, 04:38 PM
grnstang
grnstang's Avatar
if you don't put the shaft in the position that it came out of isn't that out of balance? and cause a vibration? or can you put it in whichever one you want
grnstang is offline
Old 04-21-2009, 05:20 PM
Tony71502
Tony71502's Avatar
The driveshafts are balanced outside of the car, therefore there's no way it could have a specific orientation. Just like crankshafts, they are balanced on a machine. I had the driveshaft in my chevelle shortened, balanced in the driveshaft shop, and just threw it in there. No problems. Also, I've pulled the driveshaft out of my mustang when replacing the clutch, and also when installing a new transmission. Once again, we just threw the driveshaft in the car and ran it. No poblems. And I take it well over 80, almost everyday on the way home from work on the highway. At least I did last year before winter hit. It's about to get the same abuse again.
Old 04-21-2009, 05:36 PM
grnstang
grnstang's Avatar
i have a vibration at high speeds but i think its because i need an alignment, my tires have feathered edges; and i am willing to bet the guy that balanced my wheels and tires didn't do it right
grnstang is offline
Old 04-21-2009, 05:40 PM
Tony71502
Tony71502's Avatar
By feathered edges do you mean the inner sides of teh wheels are worn? The only major vibration that I had above 80 in my car, and I mean serious enough to shake the steering wheel, was a bad ball joint. My buddy has a bad vibration in his car but that is because his transmission has a bad tailshaft.
But, if your insides of your tires are chewed up, you may have an alignment problem and not a tire balance problem, even though the wearing of the inside of the tires will cause them to become unbalanced. I had to buy adjustable caster/camber plates for my mustang, even with stock front suspension, in order to get it aligned properly, so it would stop chewing up tires that were balanced when they were put on the car.
Old 04-22-2009, 07:42 AM
mattkoly
mattkoly's Avatar
I agree with you Tony71502, that is why I'm having a hard time grasping the whole rotate it 180 or even 90 degrees and having vibration go away. that said, i did rotate the driveshaft and had little results.
One thing I did notice is a had a lot of play in my pinion and it changed with rotataion, so in some spots it had about 10-15 degrees of play and then in others it had very little. could this cause my vibration?
mattkoly is offline
Old 04-22-2009, 07:53 AM
AdderMk2
Banned
AdderMk2's Avatar
^^ that could easily be your problem. Have you ever had any rear end work done?
AdderMk2 is offline
Quick Reply: Driveshaft vibration after clutch swap
