1st shot of spray
Old 05-03-2009, 09:51 AM
  #21
adam1993
adam1993's Avatar
my motor didnt blow it just made a little noise and lost oil pressure it wouldnt take another shot though
adam1993 is offline
Old 05-03-2009, 12:30 PM
  #22
NotchAbove
NotchAbove's Avatar
I thought you just said you toasted the ring and piston and spun a bearing >?
NotchAbove is offline
Old 05-04-2009, 09:16 PM
  #23
adam1993
adam1993's Avatar
my motor had 73000 miles and was on the way out befor i sprayed it the rear end started wining after the bottle but it is a a.o.d and it was so fast i loved it i went overboard at the machine shop .eagle crank tru pro forged pistons forged rods girdle 7 qt oil pan heads machined with recesses for wired head gaskets plus a few dress up items .225 liter per hr holly fuel pump and adjustable billet pressure regulator. i put the motor in 3 weeks ago and havent filled the bottle yet but am looking foward to it !!
adam1993 is offline
Old 05-04-2009, 09:25 PM
  #24
adam1993
adam1993's Avatar
no #5 connecting rod bearing spun but it didnt totaly blow up i stoped driving it and promptly removed motor,,only to wait 6 months to save enough money ..the motor needed complete overhaul. every time the machine shop called me they were like you need bla bla 275.00 more ,,,weve discoverd bla it ill be 300.00 and you should also bla 250.00 on and on but im totaly happy now the car is perfect !!! i need to refill the tank again !!! N.O.S helps you find the weakest link in your auto with brutal efficency!!!
adam1993 is offline
Old 05-04-2009, 10:24 PM
  #25
08 Bullitt 2310
08 Bullitt 2310's Avatar
Isn't a rev limiter on the bottle an issue?i was told NEVER to let my car hit the limiter on the spray.Lets the nitrous build up and next time she hits those plugs........KABOOM!
Someone correct me if I'm wrong.
08 Bullitt 2310 is offline
Old 05-04-2009, 11:11 PM
  #26
TrimDrip
FudgeDrip
TrimDrip's Avatar
I know a guy that blew his car last week by forgetting to check fluid in the transmission at the track. The trans slipped going into second and KABOOM.
No more shortblock.
TrimDrip is offline
Old 05-05-2009, 01:11 PM
  #27
NotchAbove
NotchAbove's Avatar
Oh no, you are 100% right. That is a surefire way to blow a motor.
A window switch is cheap insurance for multiple reason. Stops the juice from coming on to early or shutting off too late.
jwog666
12-27-2021 08:09 PM
guitarman376
10-11-2015 01:47 AM
Webster454
09-23-2015 06:29 AM
pimp2303
09-17-2015 08:45 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: 1st shot of spray
