Battery ground question?
Hi guys i just finished doin my battery relocation and i have a quick question. I am running a cut off switch for my battery. Can i run my charge wire from the alt to the cut off switch or does it have to go directly to battery?
oh second question if i may, I am basically running 2 big ground wires one from the battery to the old quad shock location and one from the engine to the front sway bar location. Will i run into a ground issue should i be running anymore grounds? Ground and power wire used is both 1/0
this post is worthy of deletion..........anyway to the OP it is best to run the charge wire to the battery or hot side of the selonoid, I did such and have been fine
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
