A Couple Concerns
A Couple Concerns
First concern is this:
I don't know why this is this way, but do I need to be concerned? I was willed this car and I am not familiar with Fords at all.
The other is the radiator, it looks like the shroud was cut into and the blades of the fan look like they were clipped a bit, is a stock radiator this thick, or is this an aftermarket 3 row?
Thanks in advance!
I know, it's filthy...lol. It has been sitting under a tree for almost 2 years and I can only do so much...one step at a time.
Thanks in advance!
the 5.0 plate is just a cover for the bolts to get the intake off. as for the shroud it might cause cooling issues but if it does a quick junkyard run will do the trick. also the coolant port on your intake is bypassed or missing. if its bypassed but you still have egr flow you will fry your tps.
Is this radiator sufficient enough, or should I go with a 2 row?
http://www.latemodelrestoration.com/...0%201&comp=LRS
The car doesn't have many mods, just exhaust, cold air intake, rearend gears that I know of. Is getting a 2 row overkill?
Before my friend passed, he told me that the radiator was leaking really bad. I have not seen anything come out of it for the hour, or so I have had it started, totally dry. I know his dad replace all the injectors and a shop did about $2,500 of work to the car about 2 years ago, they may have repaired the radiator then.
Is it possible the hole/crack in the radiator is still there and just rusted over the 2 years it was sitting? This may be a dumb question, but I don't know if that is a possibility. How would they test the radiator, do they do a pressure check?
yes there is a cooling system pressure tester. you can always pull the rad and flush it yourself....after sitting for two years im sure there is some kind of build up in the rad...then you can find out if it has a leak.
Matt's 95 Stang
10-05-2015 07:16 AM
