No Start When HOT!? 1992 GT
Old 04-27-2009, 10:22 AM
greasemonkey
greasemonkey's Avatar
Default No Start When HOT!? 1992 GT
It has a Moroso cold air intake, Lincoln headers, BBK H-pipe straight(no mufflers or cat), Blue top ford injectors, and MSD Coil.
The car runs like a scalded dog, but as soon as it gets up to temp it will not restart if its shut off. Has good fuel pressure (and holds so if cant be injectors bleeding off) and okay spark (a little weak but should suffice). I put in a good used distributor (for the ignition module and pickup) just because. When I tried a good used coil it the spark got a little hotter but still will not hit a lick until it cools. Im a little stumped.
Anyone have any ideas? Thanks
greasemonkey is offline
Old 04-27-2009, 07:23 PM
88_5.0
88_5.0's Avatar
Double check the ignition module, and try checking your timing
88_5.0 is offline
Old 04-27-2009, 08:28 PM
84conversion50
84conversion50's Avatar
+1 on the ignition module.
84conversion50 is offline
Old 04-27-2009, 08:53 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Heat soak on the starter
WhiteFoxGT is offline
Old 04-27-2009, 08:59 PM
Riceinator
Riceinator's Avatar
If it runs fine when its hot, just doesnt start, I would lean towards a heat soaked started as mentioned above.
Riceinator is offline
Old 04-27-2009, 09:10 PM
FordMustangXBA
FordMustangXBA's Avatar
Define not starting? Does it crank?
FordMustangXBA is offline
Old 04-28-2009, 12:14 PM
91GTSTANGKID
91GTSTANGKID's Avatar
this hapened to me and it turned out to be the starter geting to hot... i changed it to a 1993 mustang starter cause it was alot smaller and now she starts everytime no problem
91GTSTANGKID is offline
Old 04-30-2009, 08:58 AM
greasemonkey
I put a used ignition module on it and then a whole distributor(so another module and pcikup). Once it cools it will start right up and I can time it. But when it doesnt start, its instant. Shut the key off and turn it back on as fast as you can and it will not start. Just cranks. I have spark, and good fuel pressure that holds. I did forget to check for a pulse. I will do that tonight. thanks
bjdutch2005
03-24-2017 03:38 AM
2007StangV6
01-28-2016 06:09 PM
StalkerGT
09-25-2015 02:41 PM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: No Start When HOT!? 1992 GT
