Stuck
Old 04-28-2009, 12:40 PM
HotpodStang
HotpodStang's Avatar
Default Stuck
I just changed out my head gaskets and got everything back together. I started the car and let it idle for a few minutes before i put my h-pipe back on then when i got the h-pipe back on and oxy sensors hooked up it started and when i touched the throttle just a little it would bog out and die. Now it won't even start anymore. Any insight would be grateful.
HotpodStang is offline
Old 04-28-2009, 01:00 PM
94ford5liter
94ford5liter's Avatar
you probably just need to adjust the timing. Take the spout connector out and move the distributor around and see if it starts. Also recheck the firing order and are you sure you got the distributor in at TDC on cylinder one?
94ford5liter is offline
Old 04-28-2009, 02:05 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Its not a good thing to run with open headers IMO. How well did it start, run and idle when it did do it???
projectresto83 is offline
Old 04-28-2009, 02:23 PM
grnstang
grnstang's Avatar
set timing, make sure sensors are hooked up correctly
grnstang is offline
mrtrodonet
09-19-2020 03:12 PM
DreadPirateRoberts
09-26-2015 02:11 PM
jstrothe
09-24-2015 12:17 PM
rafotree
09-22-2015 03:55 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Stuck
