Main Cause Of Overheating?
Old 04-29-2009, 03:02 PM
LesteR723
LesteR723's Avatar
Default Main Cause Of Overheating?
My fox has a new(ish) radiator, but i believe its an OEM repop, a stock crank driven fan and shroud, and stock water pump with a 180* thermostat (replaced about 4 months ago). When i was drifting (it was on a hot day) the car was overheating, hitting 210, 215 and i believe it hit 220 at one point. Is it the water pump, radiator, or fan that would be most beneficial to replace? i have about $400 in summit racing credits and was planning on replacing at least one of these. Thanks!
LesteR723 is offline
Old 04-29-2009, 03:05 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
depends. if it overheats while driving it can be blockage in teh rad/block, bad rad cap, or bad t stat.
if i overheats while at idle it could be bad wp, bad t stat, bad rad cap or bad fan clutch.
FivePointOhh is offline
Old 04-29-2009, 03:09 PM
1990lxhatch
1990lxhatch's Avatar
The main cause of overheating is too much heat and not enough cooling
Seriously, 220 is not anywhere near overheating..... especially on a hot day when you have the motor wound up and the car hardly moving. It is a little warm..... but you won't boil over until close to 260. Additionally, an 89 longblock with iron heads can take heat like that more than a few times without serious damage. Boil over with aluminum heads..... well that's a whole 'nother story.
Your condition is normal. Take care of that sexy car you got there
1990lxhatch is offline
Old 04-29-2009, 04:00 PM
Timspony
SVT Section Moderator
Timspony's Avatar
Couls be any of the ^^^^...check coolent level & radiator cap first, then go from there...
Timspony is offline
Old 04-29-2009, 04:02 PM
mstngsule68
mstngsule68's Avatar
dont forget.....is this a stock gauge?
mstngsule68 is offline
Old 04-29-2009, 04:05 PM
AdderMk2
Banned
AdderMk2's Avatar
like said before... 220 is NOT overheating
AdderMk2 is offline
Old 04-29-2009, 06:27 PM
LesteR723
LesteR723's Avatar
rad fluid is good, rad cap is good, t stat is new, fan works fine.
Not stock gauge, autometer.
Well thats good to know that 220 isn't overheating, and i have stock heads.
But realistically should i replace the pump with a high flow pump or get a nice 3 core rad?
Old 04-29-2009, 06:45 PM
FivePointOhh
in limbo
Nice 2 core aluminum rad is more than enough. IMO 220 on a 180t-stat is abnormal. Ive never seen above 205 on mine.
Old 04-29-2009, 06:48 PM
cch
cch's Avatar
-Not enough coolant
-Fans not working
-Bad rad cap
-Bad thermostat
-Bad gauge
-Bad headgaskets
-Cracked/warped heads
-Air in the system
-Blocked passage hole (though unlikely)
- Stock radiator? Could be all gummed up
Good luck
cch is offline
Old 04-29-2009, 07:07 PM
84conversion50
84conversion50's Avatar
open your radiator cap and run the car when its been sitting and see what temp the thermostat opens at. 215 is normal for a 190
84conversion50 is offline
BOB ROME
07-26-2023 01:54 PM
breaking
10-02-2015 01:27 PM
MusicCity615
09-12-2015 07:05 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Main Cause Of Overheating?
