KOER test, codes, and i couldnt get KOEO to work? help.. ( lean car )
Old 04-30-2009, 07:25 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
the computer runs off temperature of the engine.
TrimDrip is offline
Old 04-30-2009, 07:30 PM
84conversion50
84conversion50's Avatar
it runs fine. just rolling idle.
84conversion50 is offline
Old 04-30-2009, 07:32 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
ect will cause that. It should smell like fuel when at idle. Also in the winter have a cold start problem.
TrimDrip is offline
Old 04-30-2009, 07:34 PM
84conversion50
so unplugging it should make the problem disappear if its the ect.
Old 04-30-2009, 07:38 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I don't think it works that way. Do what I said and replace it. It is a 25 dollar sensor.
TrimDrip is offline
Old 04-30-2009, 07:54 PM
Bobert
Bobert's Avatar
Will this solve my idle roll or stop the codes from coming.
I dont really give a **** about the codes, i want the idle to dissapear rather then just make the codes stop, but my car idle like **** still.
I know it is lean, ghost white spark plugs... i want to solve the problem.. not make the codes dissapear ?
Bobert is offline
Old 04-30-2009, 07:56 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
guess what? mine were too and they are tan now. and you know what else?????
TrimDrip is offline
Old 04-30-2009, 07:57 PM
Bobert
Bobert's Avatar
Originally Posted by 84conversion50
have you tried cleaning your iac?
i did everything that is usually tried to get rid of an idle roll or a vacuum leak
Bobert is offline
Old 04-30-2009, 07:58 PM
Bobert
Bobert's Avatar
my car will throw the ect code if i dont let it warm up at all.
ect code was the 21 right?
Bobert is offline
Old 04-30-2009, 08:04 PM
84conversion50
yea
i have never seen an ect cause an idle roll but it can make the car run lean.
throwing parts at it may or may not fix it but since it was a code its worth a shot.
Quick Reply: KOER test, codes, and i couldnt get KOEO to work? help.. ( lean car )
