Rear end clunk noise. Please help
Last night I noticed that when I would get off the gas and it would shift, I would hear a clunking noise coming from the rear end. Once I got home, I would put it in reverse wile the brake is applied and it would make the same noise, but not so much when I would shift it into drive.
Here is a list of things that have been done: New shocks/springs. Upper and lower control arms. Removed quad shocks, 245 tires. UV joints were replaced last season, maybe 2000 miles on them. Transmission was rebuilt at the same time the UV joints were replaced along with new poly trans and motor mounts.
What could it be? Is it time to put gears in it? Also the balance weight on the nose of the rear end had a broken bolt on it so I removed it. Is it needed? Thanks for your help guys!!
Also not to sound dumb, but what exactly are the torque boxe's? and what should I look for as far as cracks.
Thanks
Torque boxes are where the lower control arms are mounted to the frame.You could do the cover on in nuetral thing,The problem is that the spider gears can wear and if so you can't see what is sloppy with the cover on so.........
