87-93 Tanny Fitment?
Old 05-04-2009, 07:24 PM
turbosha
turbosha's Avatar
http://nashville.craigslist.org/pts/1152665788.html
i got one
turbosha is offline
Old 05-04-2009, 08:25 PM
j-wigg
j-wigg's Avatar
upgrade the bearing retainer on the trans if it wasnt already done.
j-wigg is offline
Old 05-04-2009, 08:44 PM
AdderMk2
Banned
AdderMk2's Avatar
Originally Posted by projectresto83
94/95's will not work on a fox without changing the input shaft, if you were to use the 94/95 bell the shifter would come thru the floor about 2-3 inches farther back, not good.
IDK where the hell you got 2-3" from.. the SN95 trans is 11/16" longer!
Originally Posted by j-wigg
if a 94/95 bell were to be used doesnt the driveshaft need to be shorter also. stock would be too long. i wouldnt mind my shifter being a few inches back.
Yes, by 11/16", if you did not shorten it, you could cause binding in the U-joints and possibly crack the tailshaft housing if you hit a big enough bump to compress the rear suspension to the bump stop
Originally Posted by mjr46
crossmember mod would have to take place I believe too.
there is SOME play, but it is very likely the tack welds would have to be cut
AdderMk2 is offline
drfister
05-03-2018 10:38 PM
carid
08-25-2015 08:17 AM
RADIALPRINCESS
12-23-2003 01:41 AM
88SaleenStang
12-22-2003 08:54 AM
jhogan2424
09-02-2003 12:04 PM
Quick Reply: 87-93 Tanny Fitment?
