Missfire at Idle.
Old 05-01-2009, 01:00 PM
Riceinator
Riceinator's Avatar
Default Missfire at Idle.
Hi guys,
I have been trying to hunt down a pesky misfire at idle. I am not sure which direction to go in first. I have replaced PCV valve ,screen and rubber grommet, distributor, ignition coil, ignition module, wires, plugs. Pretty much the entire ignition system is new. It drives and pulls hard, but has a misfire at idle. What should I do?
Riceinator is offline
Old 05-01-2009, 01:10 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Have you cleaned up your 10 pin connectors before?
ryan_89_mustang is offline
Old 05-01-2009, 01:37 PM
Riceinator
Riceinator's Avatar
Which 10 pin connectors?
Old 05-01-2009, 01:41 PM
ryan_89_mustang
The ones that look like salt and pepper shakers on the back of the intake. I am going to do mine soon to see if solves some of my intermittent problems. http://www.fordfuelinjection.com/?p=85
Old 05-01-2009, 09:56 PM
Riceinator
Riceinator's Avatar
ttt....
anybody else have any ideas?
Old 05-01-2009, 10:35 PM
lx5.0
lx5.0's Avatar
have you tried to clean your maf
lx5.0 is offline
Old 05-01-2009, 11:08 PM
08 Bullitt 2310
08 Bullitt 2310's Avatar
I had an intake gasket leak do something very similar.It was the base to plenum gasket.
Possible vacuum leak
08 Bullitt 2310 is offline
Old 05-02-2009, 03:41 PM
ryan_89_mustang
.....He has a 87
Old 05-02-2009, 04:09 PM
NotchAbove
NotchAbove's Avatar
You didn't say rotor, but I assume you replaced yours ?
NotchAbove is offline
Old 05-02-2009, 11:11 PM
Riceinator
Riceinator's Avatar
How would I be able to pinpoint a vac leak or an intake gasket leak? Carb clean trick?
And yes, rotor is new.
Quick Reply: Missfire at Idle.
