Transmission crossmember question.
Old 05-02-2009, 10:04 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Alright I went and did some driving tonight and I was up to about 4500rpms in 3rd and the shifter was shaking very violently. I have looked at the motor mounts they seem a bit sloppy but i don't think it is enough to cause this.
When i noticed the vibration getting really bad i shifted to 4th and it still seemed bad so i slowed it down. When i rev the car when sitting there is only a small vibration which doesn't seem serious.
Now I replaced the front u joint last fall a little while before i put her down and the rear one wasn't sloppy or frozen so i just greased it so it shouldn't be the u joints. You guys have any ideas for something i could check? Thanks
ryan_89_mustang is offline
Old 05-02-2009, 10:26 PM
AdderMk2
Banned
AdderMk2's Avatar
for the cost of a U-joint... just replace the rear one
AdderMk2 is offline
Old 05-02-2009, 10:33 PM
ryan_89_mustang
I actually found one laying around that I am going to throw on when i get the time. Is there a way to see if the tail shaft bushing is in good shape without taking things apart?
Old 08-06-2009, 08:30 PM
jockoal
jockoal's Avatar
Cool Transmission Cross member install
When you install an adustable cross member the tubes need to be welded to secure tubes to the cross member..Failure to do this will result in excess movement of the transmisssion and drive shaft, thus causing the shift lever to dance around...AL
jockoal is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Transmission crossmember question.
