AFR 165S 1402# ?
AFR 165S 1402# ?
OK I am finaly going to put my 302 back to gether but I cant seem to remember wich way to install them I noticed that there is a helecoil in each head in side the air hole 2 total
no matter wich head I put on the driver side there is a hlelicoil on the front air hole
any info would be greatly welcomed !!!
on the afr heads you'll have to install the thermactor plugs in one side as the dowels for the accessory brackets screw into the inside of the thermactor plugs as you'll notice that the inside of those plugs are threaded, that is fo this very reason, install them so that whatever head you decide to use for whateverside that there is a open hole at the back for the thermactor air tube....your afr heads should of come with two thermactor plugs, if not go to summits website and type in thermactor plugs, and you'll see what you need.
